Titojeep
I converted over to fleet charge last year when I replaced my radiator. The other day I decided to check my coolant with the test strips. PH and temperature protection were great, however nitrate shows HIGH with the recommendation being to "flush" as per the little card that you match the strip to. Should I be concerned? Am I missing something? Is there something causing my nitrate to go high, or is there something wrong with my test strips? I recall testing the fluid shortly after installing it and didn't see the nitrate high? Your feedback is greatly appreciated.
