idiabuse
Burned down
Now that this topic has been reviewed, I like to compare to my burnt down 7.3.
I did the same exact damage to the outside of the piston but the wrist pin had no damage.
This is the second time I fix the same problem, scored piston.
Both times I have to admit that I was the reason it melted down.
I turned the timing up by simply twisting the INJ Pump.
Soon after that the engine started making sump oil.
the second time It started ticking.
Both teardowns found rear cylinders scored 1 cylinder each time.
First teardown I find that one oil squirter was clogged.
second time I blame the Timing wich was my dumb ***.
I just picked up the last items to finish my build.
My build is all turbo OEM stuff but it will be tight quench.
So I fear another meltdown. I wish I could order a .070 head gasket
but Cometic hates our engines
I have seen a thin copper gasket for marine 351 Ford Engines to add to the existing head gasket, but I guess I am stuck with what I have. Victor Reinz brand.
I see the plate used to locate the pin oilers but in the pic I dont see how it works, any additional info you can provide or maybe a picture of another angle?
Thanks in Advance!
So I am on the same boat with my build, good luck to you guys with yours
Javier
Thanks in Advance!
Javier
