Factory turbo leaking oil where CDR meets valve cover. Part # for seal?
dieseldirt
Vermont
I got my CDR valve replaced and now the rubber seal/grommet that seals the CDR to the valve cover is leaking.
Need Ford or International part number for this seal.
E8TZ-6A892-A is Ford # for the CDR to valley pan grommet on the Non-Turbo IDI's.
However on the factory turbo the CDR is mounted on the driver side valve cover and connects to a hole in the valve cover directly under it.
I was finally given F3TZ-6A892-B for the factory turbo specific seal for CDR to Valve Cover. But this part is not available.
What do other factory turbo owners do for this seal? Is there another part # that will work? Or will the one for the Non-turbo work?
Pictures:
dieseldirt
Vermont
So I tell them it is a S-series or 4700 series truck with a T444 ?
And all of them had valve cover mounted cdr valves?
This is the only way to get the valve cover specific grommet? No way to get one from ford?
I always see people posting the E8TZ-6A892-A...have never seen any part numbers posted for my application
thanks
