Ok, so the swap went pretty well. Started at about 2:45 this afternoon and I drove the truck home at :715 this evening. It was about a 4 and a 1/2 hour job, and this included changing a caliper. Bigrigtech helpin' me almost all of the way! Thanks again for the help!
First, the D50 was cursed and swore at a couple times, and then removed. After the wheels and brakes, and steering linkages, the pivot bolts were first to go. Then the U bolts came off and one piece at a time the D50 was dragged, kicking and screaming, from the truck and thrown into an ever growing pile. Some of them bolts wouldn't have come out without our secret weapon!
Once all the Dana 50 junk was out, the pivot brackets, the springs and shackles, then the process of hanging the D60 begins...
First, we had to do a small frame repair that we never noticed before. The truck must have been hit on the right hand side, it tweaked the front frame horn a little, but nothing serious.
On goes the track bar bracket, which does bolt to existing holes already in the engine crossmember as many have pointed out before.
Then it was simply reverse the process. Install springs into the D50 locations, roll the axle under and finger tight the U bolts up, bolt the track bar back into place on the axle, hook up the steering (RIGHT NOW MY WHEEL IS 90* off
, but that is getting fixed RIGHT quick!!)
The truck handles much differently I find, it's tighter, repsonds better...but it's still rough as hell!
Does this mean I have an F350 now? Just wait till the dually swap happens!!
