Exhaust System Suggestions?
frydaddy
I currently have the 2 1/2 inch stock exhaust system -Lame and I am undecided on what to replace it with. Here are the choices I have found so far.
A) Dynomax Ultraflo kit (#19430) which is a single exhaust designed for the truck. -goes from 2.5 inch y-pipe, to 3 inch, to 4 inch, and then 5 inch tip
($320)
B) Custom Dual 3 inch w/ Magnaflo mufflers - 2.5 inch off of manifolds and then directly to 3 inch duals (would have to come out in front of the rear axel)
($300 - $350)
Keep in mind I don't want to loose too much low - end torqe. Any other suggestions? - or which choice should I go with?
jauguston
Retired
Bellingham, WA
Your decision is going to hinge on how much noise you want to make. Choosing one over the other is just going to be how loud they will be. Changing the exhaust system is not going to change the level of performance in any meaningful way, you are just going to make more noise. Been there-done that (-:
Jim
f-two-fiddy
Duluth, Mn.
Just get the Auto Jet mandrel bent system. Comes with the Y-Pipe an flow thru muffler. I've got one on my 85, and couldn't be happier.
reklund
Henderson, Nevada
jauguston said:
Ryan,
Reread the OP and the answer will reveal itself (-:
Jim
Whoops... :oops:
I was gonna suggest an MBRP kit for a PSD, but that won't work on a N/A engine...
Ryan
160k87F250
not rocket science
York, PA
I have an Auto-Jet y-pipe on both my trucks and couldn't be happier. I just used a straight 3" pipe, then attached a muffler, then had custom tail pipes made w/ stainless tips.
John
fsSnowboard
Greenville, SC
i want to do a Magnaflow flow through muffler in either a 3 or 4 inch kit dumping out infront of the rear axel.
seanpistol
southern california
i found a used banks y-pipe and hooked the hyperpermax 3 1/2" exhaust up to it. the difference between now and stock is night and day! did it all for about $350.
frydaddy
Does Auto Jet make the whole exhaust or just the Y-pipe?
seanpistol
southern california
you can get either just the y-pipe(which i believe is $164), or the whole free-flowing exhaust(which i have no idea what the price is on that).
