frydaddy
- Joined
- Sep 11, 2006
- Posts
- 19
- Reaction score
- 0
I currently have the 2 1/2 inch stock exhaust system
and I am undecided on what to replace it with. Here are the choices I have found so far.
A) Dynomax Ultraflo kit (#19430) which is a single exhaust designed for the truck. -goes from 2.5 inch y-pipe, to 3 inch, to 4 inch, and then 5 inch tip
($320)
B) Custom Dual 3 inch w/ Magnaflo mufflers - 2.5 inch off of manifolds and then directly to 3 inch duals (would have to come out in front of the rear axel)
($300 - $350)
Keep in mind I don't want to loose too much low - end torqe. Any other suggestions? - or which choice should I go with?
and I am undecided on what to replace it with. Here are the choices I have found so far.A) Dynomax Ultraflo kit (#19430) which is a single exhaust designed for the truck. -goes from 2.5 inch y-pipe, to 3 inch, to 4 inch, and then 5 inch tip
($320)
($300 - $350)
