Excursion question
fields_mj
Brazil, Indiana
I'm considering buying an Excursion. My budget is $10K right now, but I'll probably go up to $12K or so. I know that the fuel system is an expensive repair/maintenace item that has to be done every so often, but how often? In other words, how many miles will a set of injectors and a pump go before then need to be rebuilt?
I've heard there were transmission issues with the early 01, are there any other bugs that I should be aware of?
What kind of fuel mileage should I expect on these? I've been under the impression that 18~19 is pretty much standard, but I have seen them "advertized" on CL with 21 and 24mpg on a 4x4. Don't get me wrong, I know how trust worthy a CL ad is. Just curious what folks around here are getting. This vehicle would see at least 90% of its use on the highway at speeds of 60 to 65 mph, and I'd probably go so far as to get what ever I needed to re-program it to be as effiecent as possible.
Thanks,
Mark
94f450sd
somewhere,ma
the psd doesnt have an injector pump.it has a high pressure oil pump.its rare for one to die.keep up on the oil changes and fuel filter changes,the injectors can last as long as the engine.
Diesel_brad
Dunce
gilbert pa
The transmisssions are the same from 99-03(the 4r100)
then then you got the 5r100(torqueshift) in 03-05 and they came with the 6.0 or the gasser
fields_mj
Brazil, Indiana
Good to know. I know the injectors get re-built rather than replaced. How often to they need rebuilt?
02x72
Des Moines, IA
Wehave the stock set of injectors on ours at 300k, minus one that went bad a few years ago. Ive never heard of anyone needing to replace them, they always do it as an upgrade. A lot depends on the driving style as for fuel mileage. When my dad drives it he gets around 20, I get 22-23. One thing you will want to get though is a chip, we have a DP and love it, better mileage and an unbelievable amount of power. Other than that the pedistal and turbo o- rings are prone to leaking, along with the 'non-servicable' plug on the HPOP, even though it is servicable.
Trannies built from 07/27/00 to 03/23/01 had a mechanical diode in it, that was a problem.
snicklas
6.0 and Loving It!!
Staff member
Administrator Moderator
Greenfield, Indiana
I have an 03 with the 6.0 and TorqShift 5 speed transmission. On the Interstate I get ~20mpg. Mixed commute is ~15. You will love an Excursion. I do not plan on getting rid of mine..... EVER!!! The PSD's are good engines. I agree, keep up on the maintenance and you will be good for a long time. I have 109k on mine, and it has all the factory parts on it. There is no set interval on injectors like on an IDI.
