Engine removal questions
fordhorse
franklin ohio
I have a 93 7.3 and am pulling it to reseal. Before I start I need to know if I can pull it with the turbo or if I need to remove it first. I also need to know where the lift point would be since i cant use a carb plate and any other helpful info or tips. I have removed and rebuilt a gas engines before but diesel is new territory. Thanks
NO_SPRK
User & Abuser
Santa Rosa, Ca
Turbo will need to be removed. There are factory hooks bolted to the intake manifolds/cylinder heads. I like to remove radiator too.
Sent from my SCH-I605 using Tapatalk
dunk
Dunce
NJ
Never pulled a diesel so can't comment on that aside from that there should be lift rings on it unless someone removed them. I pull the hood and rad support to get engines out of these trucks. Not too much work and makes it much easier to go straight in and out. Better visibility for lining up mounts and easier access to get everyone else apart and back together.
NO_SPRK
User & Abuser
Santa Rosa, Ca
Radiator support? Take the front wheels off if you need to. Too much work. The radiator itself is easy to remove. Just heavy
jas88
Greater Austin, Texas
I like to pull the core support as well in addition to taking off the front tires and letting it down on blocks. I just don't like that 1200 lb. motor that high in the air. Also, if you pull the core support, you can leave the hood in place.
cpdenton
Truck needs paint.
Conway AR
Pull the starter and the oil filter too. It gets you some more clearance around the engine crossmember. Also, the crossover pipe will need to come off.
NO_SPRK
User & Abuser
Santa Rosa, Ca
Once again ive never pulled a starter or oil filter to remove a engine. .
I always pull the hood and radiator. Slide a liftle forward and lift out
NO_SPRK
User & Abuser
Santa Rosa, Ca
These engines are not as heavy as you think. Under 950lbs
89Laredo
Underemployed
Not Canada
I read somewhere that they were like 1300.
My 6.9 was a total pita, I'd pay someone to do it if I could. .
NO_SPRK
User & Abuser
Santa Rosa, Ca
Ive had 3 complete idi long blocks in my truck for scrap and I was surprised to see that they weighed mid 800 pounds each
When I pulled my engine I removed the fan, radiater, starter, oil filter and left the hood on the truck. I connected very close to the intake air horn and really pulled ******* the chains. They were almost straight across the engine. No need to remove the hood. When I installed the engine I removed the hood springs so the hood would go back towards the windshield more but. I needed a 2x4 to prop it open. Just placed that in the battery tray. worked fine. Yes, pulling that much weight up over the core support is frightening but with the correct hoist its no problem. I used a big commercial engine hoist for that. Not a horrible freight lite duty hoist for that job.
jaluhn83
Upper Marlboro, MD
I've never pulled the radiator support, but I've also always used a forklift, tractor or heavy a-frame to pull the engine - if I was using the standard engine hoist I'd probably do it that way.
I've pulled/installed motors with the starter & oil filter, and with the trans installed too. The key is getting the angle right and having the right gear. Last time I used a frame rigged off the front end loaded with 2 cables and a winch - made it real easy to lower and rotate it right into position.
Every time I pull engines in these trucks, I completely remove the entire front clip.
It's actually less difficult than just the rad support IMHO, it offers a tremendous amount of room and an added plus you can clear out the debris from cowl drains and many other little things.
Makes painting frame easy makes access to engine to trans bolts easy, makes the entire job a piece of cake.
Dig around for my brown bruin build thread and check it out. It's in my mind easier and better than over the rad support or removing rad support.
JM2CW
Al
idi_econoline
No Bed For Me!
Northern California
Hey, smile, fellas! Life could be worse! Guess what I'm doing this week???????? LOL LOL LOL LOL
This pic is from last time.... or was it the time before????? :frustrate :(
