mabc926
Mojo
Void
Void
Void
IDI engines are cheap and with enough luck You can get a good one, I would keep it and drop another engine on it, You said there is a lot of work on the truck so no sense on selling it when You could enjoy all Your hard work and $$$$ You put in it.
If you have to, an engine like this can be swapped in one full day with a rented hoist. 2 days is more realistic though. A good break in the weather and you can perform the swap on any flat, paved surface.
i can have one out in about 2 hours, and the front end off. considering everything goes good and i dont run into no problems, and i can have another engine setting in there but not running again in one day, but 2 days i can do, when i swapped mine the second time it was out in about 2 hours, then the other one was back in and ready to run in a whole day, just had to change IP but at the end of the day i was too worn out to do it
wonder why???? i did the same sort of thing--SOME years ago,when i was working a full time factory job,and mechanicing all night long--------NO MORE!!!!!
After you blow a few up its no problem to swap them, hell the first time i done it i used a shade tree second time i got the luxary of a garage but i also got an awsome engine hoist that flipped over and dropped my engine on the floor
....yeah.... not everyone blows an engine every week so I figured 2 days would be fair for some one that doesn't
