Engine bit the dust.
Exekiel69
IDI engines are cheap and with enough luck You can get a good one, I would keep it and drop another engine on it, You said there is a lot of work on the truck so no sense on selling it when You could enjoy all Your hard work and $$$$ You put in it.
sassyrel
iowa
x's 2!!!!
david85
Campbell River, B.C.
If you have to, an engine like this can be swapped in one full day with a rented hoist. 2 days is more realistic though. A good break in the weather and you can perform the swap on any flat, paved surface.
dyoung14
Is getting worn out
spencer,tn
i can have one out in about 2 hours, and the front end off. considering everything goes good and i dont run into no problems, and i can have another engine setting in there but not running again in one day, but 2 days i can do, when i swapped mine the second time it was out in about 2 hours, then the other one was back in and ready to run in a whole day, just had to change IP but at the end of the day i was too worn out to do it
sassyrel
iowa
wonder why???? :rotflmao:rotflmao:rotflmao i did the same sort of thing--SOME years ago,when i was working a full time factory job,and mechanicing all night long--------NO MORE!!!!!
dyoung14
Is getting worn out
spencer,tn
After you blow a few up its no problem to swap them, hell the first time i done it i used a shade treeLOL second time i got the luxary of a garage but i also got an awsome engine hoist that flipped over and dropped my engine on the floor:eek:
david85
....yeah.... not everyone blows an engine every week so I figured 2 days would be fair for some one that doesn't:rotflmao;Poke
65sixbanger
New Braunfels, Texas
Oh man........
http://kokomo.craigslist.org/pts/1923467279.html
What fun could I have with that?
I would go for a 6.9, but that is just my opinion.
If you have something else to drive I would take this opportunity to start all over with a new motor. Get a 6.9, bore it out and get new pistons and check the crank for out-of roundness. New main and rod bearings. after that you'll have a really good bottom-end on this motor that will last a really long time.
bob123456789
