motox tech
Does anyone know where to find a write up for swapping out the mechanical lift pump for the electric? I looked in the Tech article section but had no luck!
Search IDI Tech Articles for "How to replace your mechanical fuel pump with a Facet Duralift electric fuel pump".
Not quite. The FIRST STAGE of the fuel pump supplies the bowl / filter. The filter supplies fuel to the SECOND STAGE of the fuel pump, which unltimately supplies the rails. But indeed, that's still not "injection pressure", as it's only about 60 psi (first stage is only 10-ish psi). This is why a proper e-fuel conversion replaces the mechanical pump AND the bowl, with a single-stage pump and a stand-alone filter/separator.well in a nut shell, the fuel pump only provides fuel to the bowl.
the bowl filters it and heats it.
then send it into the fuel rails internally into the head via a passage pretty much parallel to the oil rails.
