bike-maker
I got my hands on a Carter P4070 electric fuel pump that I want to put in my fuel system in addition to my current stock lift pump. My plan is to Y the fuel supply line right after the fuel selector valve, and run one fuel line through the lift pump, and the other through the electric fuel pump, then Y them back together at the inlet to the fuel filter. I also scored some check valves for each leg.
Running the two in parallel like this with check valves will allow me to run the truck primarily off of the stock lift pump, but be able to run off of the electric in case the lift pump dies or to prime the system. My question is where to put the check valves. I was thinking one right after the electric pump, and the other right after the Y right before the electric pump (making them both right after the fuel selector valve).
Your thoughts?
I know at least one of you is running a similar setup (Midnight)
Your thoughts?
