Just pointing out that eventually something will leak or fail no matter what is in it. I'm sure Evan's is good stuff but I just don't want to have to carry $320 worth of coolant just in case something fails going over the pass and no one has it sitting on a shelf. I like to be able to walk into a truck stop and grab a couple gallons of coolant when I'm on the road (It's convenient). Lot's of stuff can fail even at 7 psi - Just saying
Getting back to the point... For those that want to run ELC, most products will cause gasket failures because of the OAT formulation. To my knowledge Final Charge is the only typical ELC that meets 14603 and is okay for use in our engines. I've heard CAT ELC is okay too but I haven't researched it. Yes, you can use Evan's but it's out of the price range for most people that drive a truck that is 23 years old. The only reason I don't run SCA coolant is I don't like test strips and using additives (I use them at work every day and that's enough for me).
Well that is a great reply and a great way to think, yet is it a few players short of a team.
Unless you run into offroad woodpiles or drive into forest making your own trails, or forget to tighten
all your worm clamps, or use used hoses from the JY, or have a leaky radiator you rather keep using,
or still skipping down the road with bad oil cooler seals, you may never need to purchase any EVANS coolant.
I would have to agree with your theology.
Me and a few of us here actually dont pratice those theories.
I plan on driving my truck anyplace USA and my truck is ready to go anyday I please.
I just have to keep banging the drum because some just cant see the light yet they claim they see stars.
The most important purchase you make after owning your vehicle is the fluids you purchase.
Some here do just fine changing oil every 3 weeks and coolant every other year, if you can afford it GREAT!
Is it the best way to maintain a vehicle? Maybe for some yes, Not for others.
Some would say they dont ever check coolant and use water and they have 350,000 miles on it. They SAY.
I am saying that everything you learned about green coolant or red from the auto part store wont help you
when you actually purchase the REAL DEAL.
I am @ 10,000 miles on my rebuilt 7.3 and I do not plan any oil change, I will take samples and kep driving.
It works for me just fine doing this.
I purchased EVANS because I hated
Just saying that will never happen to me, but you? it will still happen.
I use a 4psi cap that is all that is needed. Driving 80mph loaded with 8,000lbs enclosed trailer I can pull over 500 miles into the trip and pop open the radiator cap and stick my face on top of the open radiator and view coolant level. No matter how hot it gets.
You swear you will have problems, well your right, you have to eliminate all the other cooling issues you have not yet considered.
I solved all of mine and I added a $40 NAPA coolant filter.
I like driving better than fixing.
I never have to go into a convienence store to buy another bottle of coolant again.
I do have a half a gallon of EVANS in case any of the 3 other vehicles need it.
Javier
