E4OD OBD1 Scanner codes
ISPKI
Granby CT
Does anyone have a list or a link to a list of the trouble codes for a 92-94 7.3 idi E4OD? Specifically looking for a list of code definitions for a 1994 F-SuperDuty with an E4OD.
gandalf
Senior Member
CA &/or Maine
I have 3 lists of codes for the E4OD. They don't specify which year, but I don't think they changed drastically from year to year, as long as they were based on the standard E4OD. I'll let you decide that.
ISPKI
Granby CT
You are fantastic, thank you.
I scanned the truck today and pulled codes 23 and 26.
Looks like oil temperature out of range, seems that suggests that it was too cold?
Also - Throttle position sensor out of range. That is mounted on the side of the IP I think and is adjustable? I will have to look into both a little more closely. Glad to see that it didnt pull torque converter slippage detected.
zemmeron
