InnovativeAV
So we've had this transmission on here ever since I got it rebuilt. We put on a new FIPL sensor and we have idol adjusted at 1.1. I had a broken wire that occurred over my pumpkin for the VSS, but that has been since repaired my tack works perfect. I do have another PCM on the way that I found from an exact 93 F250 7.3 IDI with the E4OD. I am still waiting for that it just hasn't arrived yet. I am going to put the new transmission solenoid repair harness on today that I ordered from our forum suggestions. The problem I am getting still is it still seems to be in highline pressure it just shifts hard enough that you feel the vehicle rock back-and-forth when it shifts. It doesn't shift hard all of the time and it's not really a specific gear when the vehicle is cold it shifts perfect after it is warmed up that is what it tends to shift harder. But it has been known once or twice to even shift hard when it was cold. The transmission shop that rebuilt it wants to charge me $80 per hour to decipher electrical although I believe I've pretty much deciphered everything except for putting in aNother working PCM. Which is probably good to have a spare on hand. Not sure if I missed any other electrical items but I am assuming that I am pretty much rolling out there electrical issue they're talking about except I have not checked the MIPL, because it seems to shift through its gears fine it's just shifting hard.
