turbo elk
I went to order the tube from the Bronco graveyard and it says its for small block only, does anyone think that will be a problem?
Is the new trans mounted to engine?
If not may want to trace bellhousing pattern on cardboard a d see if it will mount.
If yer dipstick hole is smaller this sounds like a sb case not diesel.
Is there not a rubber grommet to fit in hole to insert tube into???
Pics if you can please showing old vs new???
