tbryanh
I installed the pump and separator near the front fuel tank between the driver's side frame rail and the tail piece of the transmission.
Here is a close up view of the install.
The mounting plate is bolted to the underside of the van bed.
The metal straps keep the mounting plate from vibrating and add additional support.
The control box is behind the driver's seat, and the round access cover next to it is for the Racor. It is removed to gain access to the top of the Racor when the 30 micron filter needs to be changed.
Here is the wiring diagram. There are simplier wiring diagrams. I wanted to have an on/off switch for the pump and a buzzer to remind me to turn the pump on when the engine is on and to remind me to turn the pump off when the engine is off.
