Good afternoon, colleagues. I bought this truck. It had been abandoned for years and the last time it was started was 3 years ago.The injection pump was damaged, so I had to buy a rebuilt one that was bench-tested. The injectors were also serviced.I was finally able to install the entire system, but a lot of smoke is coming out of the engine. I thought it was residual diesel in the exhaust, but after an hour I turned it on, the abundant smoke continues.
Another issue I'm seeing is that the engine only turns on when I put the glow plugs on. If after being on I turn it off for 1 minute, it takes a while to turn on if I don't turn the glow plugs back on.
