E350 rearend
83ford
ford diesel baby
calico rock.arkansas.us
I've been wantin rear discs for awhile now and I came across a e350 rearend on Craigslist cheep.how hard is the swap gonna be.and where can I get a yoke cause it's got the flange style yoke I guess that the two flanges bolt together
It's a 99 rearend
laserjock
Almost there...
Have to move the spring perches I believe. You should be able to get a flange that will mate to it. I think about all the later trucks used those. Should be an off the shelf item but I don't know how cheap.
83ford
ford diesel baby
Alright how hard is it to move the spring perches?
here's a pic of the rearend
laserjock
Almost there...
There's cutting and welding involved. Have to get it all lined up straight or it will track funny.
BDOGONE
florida
Watch the bolt pattern. They swapped in there somewhere. 8x6" to metric? Maybe?
kuskoal
Yokosuka, Japan
Is it a D60 or D70? Either way they will have a D60 ring gear of 9.75". Or do a 99+ sterling swap and get them re-drilled for 8-6.5
SebastIDIan
NW Georgia
This.
Measure not twice but thrice, cut once should be ez.
Does the gearset match the front? (if 4x4)
Gonna need a new master cylinder so the discs don't drag and might need to address the proportioning valve, no idea about ABS. Would be a great time to ditch the vaccum booster for hydroboost.
83ford
ford diesel baby
This.
Yes it's the same gears it also says it's 8x6.5 are they any wider then a normal single rear wheel truck axle
83ford
ford diesel baby
Are the danas as strong as the sterlings cause this is goin in my lifted truck I don't need anything weaker[emoji23]
compressionignitionrules
Bluevale ON
a dana 70 E350 dually rear axle is way too wide for your old Fseries. are 10.25 Dually axles expensive there? I've tossed several on the scrap load as I can't even get $150 for them! not even any interest.
if you are using it for single wheel application it is going to stick out way past the body.
83ford
ford diesel baby
It's not a dually axle it's a single rear wheel.but you cant find dually axles here that easy
