redneckaggie
rebel w/o a cause
I am not seeing how it is either unless some of his other things(ie superpump,reg, or something else he has done) caused the pump to go bad but idk im not there in his shoes.
with an avatar like that, you gotta at least get the thing running right.
). From my experience with the carter pump i would recommend it.....Just an FYI for those looking at suitable electric lift pumps.Fuel system worked flawlessly. I have my regulator return plumbed into the primary filterhead pre-pump. The only issue i have found with this setup is if there is air in the loop there is nowhere for it to go. So i had to manually bleed the loop (not hard) and then it was just fine. The engine return system is more than capable of getting rid of air, however maybe not 6' of 3/8" line, and 2 filters worth of air.
