Down pipes in , Ideas on intake ?
d41
calif. central coast
Finally installed my new down pipe, Man was fords pipe a freakin joke or what ? Drilled a hole in the narrowist point and measured with depth mic , 1" at best. Now I'm thinking of opening up the intake any ideas or where to start?
Thanks,
Bill
Ironman03R
Risingsun, OH (NW OH)
Do a search on "cowl air". Use a piece of 4inch aluminum dryer ducting and cut a hole in the fire wall by the brake booster. I did this to my truck a while back and have been very happy. EGT's are lower and I have had no problems with this set-up.
There are pics in "my garage"
d41
re:
Hey thanks,
How big of a hole did ya cut in the fire wall ? Did ya run into any problems in doing so,
Bill,
Seekers
Spokane/Coeur dAlene
The banks is right at 2 5/8" inner dia at the bottom and it's 2 1/2 at the top id. I actually have a brand new one that I don't need if you want it. $95 del to you there in napa ca. and I can send you a pic if you want. Or anyone else, shipping might be a little more.
d41
re:
I did get the banks, Went in easy enough, Had to cut the lip on the fire wall and bend it back, The part that gave me the most trouble was fitting that marmon clamp back on, With the new down pipe & free flow exaust my EGT's droped about 200 deg.
It took a while talking to Banks as to what down pipe I wanted, They said they don't have p/n's for these that they pull them out of kits ??? I think I paid around $110 for mine a few months back.
Good Luck,
Bill
Ironman03R
When I got my banks DP it was the same diameter from top to bottem. I measured it and it was just a hair over 2 3/4" ID and 3" OD. They use thick wall tubing on it. On mine I did not have to modify the lip on the firewall, i went right in. I agree, the hardest part is that stupid clamp!
