Does anyone know what position the IP dowel pin is at on TDC of the compression stroke for the #1 cylinder?
I'm going to change out my unknown brand glowplugs and want the piston as high as possible...
This way I can follow the firing order as I change out the plugs...
It's easier to vacuum out the broken tip through the injector hole with the piston keeping it from falling out of the pre cup into the cylinder...
That's why it needs to be on the compression stroke or else an open valve will keep the vacuum from developing optimum sucking power...
Um, you know what I mean...
