adriantkt
thank's everybody,
last week we finished rebuilding the transmission,
filled with 3.5 quarters of ATF
and 2 on the transfercase same ATF,
in the weekend i tow my trailer with 2 horses(around 6000 lbs) it work like a beast a little slow on hills around 30 mph
the transmission shift smooth on every gear
everything went fine, temperature and oil pressure gauge never moved
now i'm planning to check the compression and change the oil pan gasket because it's draining a little bit of oil,
and will save money to get a turbo
Our wrists just wont bend like is needed to reach in to grab the oil pump and hold it in place when you reinstall it. Ask around and decide before you try this. If you have oil dripping from the passenger side back of the engine thats probably coming from the valley pan. Way back behind the CDR valve at the back of the intake manifold is a drain hole in the valley pan. So any oils or fuel will drain out thru that hole and can only run down over the passenger side and starter. Again.. Ask around.. We have plenty to offer here and we never sleep. This place is open round the clock. Even on holidays...
