Did R&D idi performance go out of business
Stuka
Ga
Hello everyone I was about to purchase some parts from R&D idi performance but they were out of stock i also looked around and every single part is out of stock are they no longer in business? if so that would really suck R&D was probably the only place that made good IDI performance parts if R&D is truly out of business is there anyone else I can go to for billet fuel rails and performance injectors?
DirtyWood
Earth
Call for best service. I had wondered myself about his business since everything is listed as "out of stock". I e-mailed them about getting an IP and they got back to me within 24 hours.
DougBoy66
Cass County Missouri
You have to be diligent and check for what you want regularly. If you call they will usually give you a ballpark time things will be stocked. My recent example of injectors. Had an idea of when and started checking 3-4 times a day. 12 sets came available and I bought 1. The rest were gone in less that 2 days
Clb
Another old truck
nannyfornia
No he's buried in the job's #1 priority...
Making power 1 atta time.
Don't give up on him contacting you.
Ps
Commit to a sale, tell him to put you on the list for an order of x product ( i need a pump) ect.
DisasterPastor
Sarasota, FL
I got my injectors and return line kit from Classic Diesel Designs. Theirs isn't a rail, but a much better than original and auto parts stores, ebay, etc. I installed mine about 2 1/2 years ago and no leaks so far. and doing other things, like replacing the injectors once with auto parts ones that quickly failed and then with ones from CDD, the caps, lines, rings, etc., went right back in place with zero issues. I also got their filter return line kit delete. My injectors have also been great, as well as the pump and a few other items I got from them, no issues and truck is running the best it has since I made the changes. They also have great tech support and have helped me through several issues, even on things that didn't pertain to parts I bought from them. I can't compare R&D as that wasn't the route I went but have heard good things about them.
DougBoy66
thank you
Your welcome, My advice to you if you get them is to watch Justin's video on installing them. It's a process. Not difficult but my first time I put them in I just shoved them onto the installed injectors and they leaked
