Ron... Really sorry to learn of this roadside breakdown. There is nothing you could have done to prevent this type of failure. Glad your up and running again. I would like to suggest replacing the new nappa electric with a transcold carrier pump. Knowing how well they pull fuel from under a semi trailer and be able to darw it up around 11 or 12 feet is impressive. Look at those semi cold trailers you are passing on the road. See the refrig unit up high on the front of the trailers. Then look at where they suck the diesel from to run those engines for the cooler. Its way back behind the spare tire and chains rack under the trailers. Those electric pumps have a clear removable bowl and a stainless steel filter screen in them. They will work better than anything out on the market or transcold wouldn't trust them on the cold storage trailers. I know this is after thought but use it for the future too. theres no deneying the mechanical lift pumps give us lots of trouble free miles year after year. But a simple electric lift pump upgrade makes a dry tank or a filter change easy on the batteries and starter. Glad your running again.... P.S... Put a spare carrier pump behind the rear seat.. That'll make you feel good inside....
