pig snot & greasy jello
It's amazing how one item of omission can change a diagnosis.
You figured out your problem already. Feul system contambination.
before getting nuts with the inlet screen, pull the top cover and check for solids in the feul well. If there is, your pump is done. Improper mix and/or improper purge and shutdown procedures of other feuls with diesel is the biggest killer of IP's.
Ditto on that
one item of omission. IP may or maynot be done at this point, but it's headed for "done."
Shadetree, I don't know what kind, or how elaborate the WVO set-up is on that rig, or how the WVO is filtered & processed before poured in fuel tank, but the "shaturated Fats" you refer to is saturated alright. Greasy Jello, Crisco, bacon snot, cow tallow, yogart, cholesterol laden taterchips, puddin, & got BLUEBONNET-ON-IT too!
When WVO is properly strained & filtered &
heated up enough to thin viscosity before passing thru filters & IP, then all the above listed ingredients will be liguidified & it flows thru the fuel system & IP OK.
As TC stated,
If WVO isn't purged from IP etc before shutdown, (need 2 tank setup, 1 diesel, 1 WVO) then next morning in the cool, crispy, frisky feeling twilight when 'ya go to crank that rig, everything in filter, fuel lines, IP, etc is snotty, clabbered, jelloed-up "Saturated Fats" & don't want to flow & be pumped....& what you found in inlet screen is in IP, lines, & injectors.
Kinda ******* IP & injectors....& engine innards.
Purge that thing before shutdown....run diesel thru it a few miles before shutdown. Then it needs to be cranked on diesel & warm the WVO up bigtime before flipping over to WVO.
I don't know about
"precipitate" reaction with some ULSD. The diesel should mix with WVO when it gets together.
Another tip or hint:
1. I don't know, but i've been told that if 'ya get to mixing WMO or some of those things, with WVO it tends to turn to black or discolored clabbered buttermilk in fuel filters....thus shortening filter life. I would think WMO would mix with diesel better.
2. I also don't know, but I'm convinced that folks running WVO & such should have spare IP & set of injectors laying round....just in case. I don't believe that all the emulsified water & moisture & other scary ingredients can totally be eliminated from WVO (at least by the Average Joe)...thus shortening IP & injector life. (however at diesel prices several pumps can be bought)
3. Plugging up block heater will heat coolant & block some, but won't heat IP enough to liquidify that Pig Snot that's setting in the IP if 'ya don't purge before shutdown.
Just some of my $.00002 cents for what it's worth
