dash warnings
Cincinnati Guy
Cincinnati, Ohio
My battery light, bright light warning on the dash do not work, where should I check to find the problem? Also where do I find the headlight warning buzzer at?
Cincinnati Guy
Cincinnati, Ohio
Well the bulbs didn't appear to be blown but I swapped some around and still no go.
I do think I found out why my headlight buzzer don't work is because my door button on the driver side don't work for turning on the courtesy light. also where exactly is the buzzer at under the dash? I think mine might be gone.
Sycostang67
Scooty Puff Junior
Kuna, ID
On my 95 I think the buzzer was under the dash next to the transmission hump on the driver side. I haven't looked for it on my 93.
jim x 3
1988 F-350 DRW
northern california
For 1988, the buzzer module is mounted just to right of the accelerator pedal (at left side of hump, like syco said above). Its mounted vertically - the connector plugs into the bottom. The connector has 7 pins, a row of four and a second row of three. Your photo looks to be it. Mine had a white body.
Regards,
Cincinnati Guy
Cincinnati, Ohio
I plugged it in and yup that's what it is. The only thing now is I need that push button thing for the door apparently mine is bad because if I jump the wires over it works put it don't when its all hooked up through the switch. Anyone have one they can send me? Mine isnt one of the round ones its the one that takes 3 wires.
