dana 60 swap
BROWNIEBOY525
The old fleet
south jersey
okay my font end is going to need some work and i need tires before winter so i think now is a good time to do a dana 60 swap. I am looking at this one http://cgi.ebay.com/ebaymotors/1994-Ford-F350-Dana-60-Front-SRW-354-Gears_W0QQitemZ250322821357QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item250322821357&_trksid=p4506.c0.m245&_trkparms=72%3A727%7C65%3A12%7C39%3A1%7C240%3A1318. Is this a good price it seems pretty complete. If i get this axle do i need anything else or it just bolt it? Will the springs from a 250 work with the solid axle?
6 Nebraska IDIs
That looks familiar!
haha
Anyway... Make sure he gives you the LH lower spring mount bracket. It is kinda a saddle deal that wraps around the diff. Other than that you'll need the sway bar frame brackets, unless you remove it and decide not to run it. I have the part number for those if you want them. They are FORD only.
And no, F250 springs are a big no no on a D60 axle. They are negatively arched for one thing, and secondly they tilt the axle to a different angle than is appropriate for a solid axle. Thats what my suspension shop told me when I did my 4x4 D60 conversion.
forcefed
Newark, OH
I used my f250 springs no problem. I just unbolted my IFS removed all things not needed and installed the dana 60. I bought some u-bolts and made my own spring plate out of 1/2" steel for top of the springs. Pretty simple swap, just real heavy.Make sure you get the track arm and bracket that bolts to the cross member. I had to make my own track bar and bought a drop bracket off of e-bay. Looks like a good deal right now for the axle. I would go for it.
6 Nebraska IDIs
Mike, I cant seem to find a pic of that bracket specifically. If its dry tomorrow I'll take one with it on the axle.
forcefed
Newark, OH
I did not recieve the saddle with my axle. Instead I flipped the u-bolts upward and made my own spring plates and welded my shock mounts on. But if you can get all the parts witht he axle it would be easier.
zpd307
Zumbrota, MN
650 is a good price, if you can drive tp pick it up. shipping would be a killer.
6 Nebraska IDIs
Here's that bracket I was talking about.
