Cat_Rebel
Does not compute
Not sure about the IDIs but they are awesome on the Powerstrokes. A set of 3.73 gears has a good mix of highway & towing. If your pulling, hauling, or running larger tires you'll want 4.10s. I run 265/75/16"rim tires & get about 16mpg avg. driving country roads & light to mild city. In town I turn the OD off because the speed limit is 35mph in town & if I feather the throttle it will go into OD at 35mph. So I run it in 3rd gear & don't have an issue. I pulled a trailer with mine a few weeks ago & noticed the trailer more empty than when it was loaded. Same thing with a big load in the back, you really don't notice it. Your towing mpg won't drop as much with 4.10s either because the engine isn't working as hard.How is the 3.73 with posi for towing?
If the truck in question won't be pulling trailers or hauling alot of weight then 3.55 would be just fine. But if the said truck will be used for work then go for a set of 4.10s, if you have OD & don't go on the highway all of the time they arn't too bad.
