gabbyr100rs
Well,
It's in the truck bed instead of under the front end, but its a start.
Came out of an 89 F350 gasser from CT that had been used as a plow truck. Outside is predictably rusty. The axle turns freely and with no perceptable slop (scientific term ). Plan for new bearings(except for carrier bearings if the ring gear is tight), seals, and u joints. My calipers will mate up with the 350 hubs, and are in much better shape--no rust. Tie rod and track bar are prolly rusty toast--the adjusting collars appear to be hopelessly frozen--I don't see PB Blaster getting past that stuff. Planned for tie rod ends anyway. Will renew spring and track bar bushings. Stock or **** bang polyurethane??
Manual hubs on it--one ford and one warn.
Have the 350 drive shaft that is significantly shorter than the one on the 250HD and has a double cardan joint on the "axle end". That, I assume, corresponds to the much longer high pinion on the D60 versus the short low pinion D50. Will have a drive line shop look at the dcj--the seal looks worn to me--the u joints all turn freely but they will all get replaced.
The drop on the 350 pitman arm looks identical to what is on my 250HD right now. I will compare them side by side when I swap in a rebuilt steering box--I have about 3-4 inches of steering play with the motor running. After 150K it is ready for the reman shop I suppose.
I will keep posting as I go thru the swap. If I can learn to use our digital camera, I will take some pictures along the way.
Thanks for the inspiration to tackle this! Gonna need a bigger floor jack with more lift and GBFJS's (Great Big Forking Jack Stands) to hold the frame up off the garage floor when the existing parts start coming out.
Last question is where you guys go for fastener to bolt up parts like the track bar? I want Grade 8 stuff that won't break and I don't know whether to trust what is on the shelf at Lowes/Home Depot. I can get new axle u bolts made up at a drive line shop or thru NAPA.
Thanks for the information and help. Going out to strip off the hubs--beautiful morning north of Atlanta.
