Custom Turbo System
zigzkidz
Butler, PA
I was thinking about make a custom turbo system, using the hypermax system without there turbo to cut down the cost, and maybe use somthing like a powerstroke turbo or somthing similar the hypermax one. Im not sure yet about if im going to use an intercooler or water injection. I plain on putting propane on my truck soon, it doesnt have a turbo on it now, but could i still use propane with either intercooling or water/**** injection? Any suggestion about the turbo system will help.
diesel4me2
Camping is more importanter!
northern illinois
just fyi hypermax up pipes and turbo mount are perticular to hypermax turbos.
the other turbo set ups i've seen would have to have a lot of mods done to work with them. don't know much about water/**** or propane set ups, never delt with them
chris
zigzkidz
Butler, PA
i talk to a guy at hypermax he said the turbo is a standard T4/T3 Flange mount
diesel4me2
northern illinois
i'm not very filmilar with the terms. don't know what t3/4 means. the turbos i've seen have about 3" pipe to them here's a pic of the collecter and turbo from hypermax. if thats a t3/4 then ok, i've never seen an turbo from a powerstroke. if its the same flange than i appoligze for the miss info.
chris
LUCKY_LARUE60
Oregonia, OH
A T3/T4 turbo is a T3 compressor & a T4 turbine side, the compressor side is small and can replaced with a bigger compressor wheel and housing with a T4 for more boost.
Jim
Michael Fowler
Bel Air, MD
First of all ---
WELCOME TO THE GROUP!!!!
Next- There A LOT MORE to installing a turbo than just bolting it up. The turbo must be the correct size for the engine, and the engine RPM range. Too big, or too small and the turbo won't work as well as it could. It could even be detrienmtal to the engine.
There are a multitude of good books on the subject. You need to get one and study it. Learn to do the math required to correctly size the turbo or expect to waste a lot of time and money.
It can be done- I am not trying to discourage you, but its obvious you need to educate yourself or face disappointment.
zigzkidz
Butler, PA
i have studied some books and they recommend exhaust housing .96-1.15 and the compressor at .60-.70
