Cruise Control Problem
Lug Nut
New Mexico
When using my cruise control it surges. In other words if I set the cruise on 75, it will drop down to about 72 then speed back up to 75, then drop back down to 72. This is on flat ground. It feels like someone is pressing the accelerator then letting off, then pressing it again then letting off, over and over again. What would cause this ? Truck info in email sig.
DrCharles
West Plains, MO
Not sure... Too much slack in the connection from the throttle to the servo? Or something else causing the control loop to be underdamped. So it "yanks" harder than it needs to, and overshoots...
Macrobb
North Idaho
Hang on; he's got a '93; My '93 has an all-electric cruise control, like the newer gassers. My '92 does as well...
Is the speedo surging? I'd probably be looking at the tone ring, which is what the VSS reads.
Pull off the rear diff cover and look at the ring there with all the teeth; it's mounted to the carrier and spins parallel to the wheels. Look for rust, broken teeth etc.
Yeah, complete different system. If it was a vacuum problem, cruise would be disabled.
It's common for the vss to get dirty.
Lug Nut
New Mexico
Lug Nut
New Mexico
The speedo surges but with the change in speed only. It's not bouncing around like I have seen some when the VSS sensor is bad.
IDIBronco86
