Cracked cylinder. Awesome
RocketScott
Tacoma, WA
I took this engine out of my van to swap in another. The replacement has bad compression so I started checking out the original to see if the coolant problem could be fixed. Looks like that's not going to happen. Hopefully I can put the heads off this engine onto the other to fix the compression issue.
RocketScott
Tacoma, WA
I have the other engine already but it has low compression. Need to do a leak down test on it.
The heads that came off the engine with the cracked cylinder are good so I'm hoping I can put them on the engine with bad compression.
Trying to avoid a full rebuild.
Lance
Staff online
