I recently did some work to my 92.5 idi zx5. I added an ats 088 turbo, stage 1 injectors, 3 inch down pile and 4 inch exhaust. I have boost egt and temp gauges (in the overtemp sensor spot). The thing runs amazing. I replaced my OE copper/brass radiator with an aluminum (don't recall brand). New water pump. New Motorcraft thermostat. New cooling fan clutch. My problem is that the cooling fan will not engage as the engine is working hard pulling my RV. I bought a lifetime warrantee from napa and am now on the 4th clutch in a month. Engine temps get as high as 240 and the fan still won't come on. The cooling system worked perfectly before I replaced the radiator and the fan clutch sounded like a jet engine when it engaged. Normal driving I can't get the truck over 190. Wondering if anyone has any advice for me or experienced similar. Thanks-
