knash0727
Knash
Well... Long Story...
I had a block heater and at one time it fell out. I put a expendable freeze plug in its place.
The other day I took a road trip and all of a sudden I saw smoke. I was kind of ******* the throttle at this time so I thought that was what it was until the High engine temp light came on. I stopped and realized that the plug had come out draining the coolant all over I45.
I replaced the plug, but my coolant seemed to not be leaving the radiator. After I filled the radiator up it kept getting hot. I got the truck home and pulled the thermostat. I boiled some water and put the thermostat in and it did not open.
I went to Ford and ordered the motorcraft thermostat. This thermostat looked very different from the old one. I replaced the thermostat and not it is still not working. I refilled the coolant and let it idle for a while and it did not get to hot. There was a huge amount pressure in the top hose, but it didnt get warm at all. When I backed off the radiator cap a little bit, the coolant just ran into the overflow. It sounded like it was boiling. I dont know if it has air in it or what.
I drove it 2 miles to my brother's house, and the temp gauge got up to hot. I shut it down for about 5 mins, then looked at the temp gauge and it was back down to the o in normal. I drove it home, and on the way over the gauge said it was hot again. When I pulled in I shut it down and popped the hood. The top hose was very hot and had very high pressure in it, and the bottom hose was stone cold.
Now I am confused. What should I do?
Sorry for the long post, but I am so confused on what to do.
