Coolant pooling up on top of block
BlaineDavies
Yreka
1993 7.3 idi.
It had a leak from what I thought was the heater core, replaced the heater core, and the leak seemed to move. I havent notice my temp changing much or over heating , but have noticed my fan will spin freely, a smell of coolant, coolant pooling up on top of the block under air filter and my heater doesn't work at all. What is going on?
riphip
Memphis, TN.
Can you get a picture of where it is pooling. May be from hose riser on water pump blowing back to intake. Check for leak above hose clamp on riser connection going to heater.
DrCharles
West Plains, MO
I had a coolant leak once that a shop diagnosed as coming from the left front freeze plug. I found out that it was actually from the water pump, blowing back onto the engine and running around the corner! Haven't added a drop since I put a new pump on.
These leaks can be tricky to find because they rarely drip straight down. Keep looking. Also get a coolant pressure tester and pump 'er up to a few psi. Will make a leak easier to spot.
oh, and welcome to the forum :)
dogdanblue
