Dsl_Dog_Treat
Ok update here,
Man froze my namesake off tonite under the ole gal on the fozen muddy drive,for an hour checking about.
Found wetspot around hose on head to heater core. Tightened down AGAIN! all the other dry.
Found more coolant on inspection cover...fresh.
Found coolant on left engine mount. Oil cooler.. not leaking.
Found wet area arond block heater and corroded tightening nut. Dried up when up to temp.
Water pump..dry.
Left head back lower corner was dry from degreasing when trans was out.
Right head lower bottom had substantial oil goop at head/ block mating surface. Was cleaned also on trans removal 2 months back.
Heater core has been replaced bofore but small corrosion spot lower left corner. Box was dry.. Gonna change this weekend.
Radiator had been recored before. Noted black paint buildup and core looked good and dry.
Gonna still do pressure test but gotta wait till my buddies rad shop is closed over weekend to use the adapter.
Diagnosis? Right head gasket toast?
Can't explain source of left motor mount find.
Took her out for a run to get the kids afterwards, checked same spots again. All dry.
Shut her down and waited 5 minutes and checked again. Found fresh oil/fluid leakage on right back lower head. Hard to tell if there was antifreze present though.
Not looking good eh?
Found a better fix today will cost less for now.
The local Diesel shop I have been working with has a 7.3 from a E series van. It has 80,000 miles on it but he said of the wasn't to sure of the condition of the motor (SCA)'s as he bought it as a wreck and was gonna put it in a IH panel truck. He said $800.00 and a couple DMF's and its' mine.![love :love: :love:](/styles/default/xenforo/smilies/loveeyesdude.gif)
For that price, momma even said that I could spring for a rebuilt ZF to go.
Just concerned about prior engine use, but for that price, 2 7.3's are better than one?
Ron![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Water pump..dry.
![shocked :shocked: :shocked:](/styles/default/xenforo/smilies/shocked.gif)
![thumbsup :thumbsup: :thumbsup:](/styles/default/xenforo/smilies/cool guy.gif)
![Sweet ;Sweet ;Sweet](/styles/default/xenforo/smilies/Thumbup19.gif)
Ron
