My shiny new aluminum radiator came in today, and well I was admiring it, it dawned on me that since I'm changing coolants (gotta protect the aluminum) I need to flush all the old coolant out of my truck.
I'm thinking about flushing it, then moving it into the barn, then installing the new rad after I finish with the other work.
1. Are there any special things I have to do to flush it (because of the oil cooler).
2. After flushing if I remove both block drains is there anyplace in the engine that water could pool and cause me problems (it is currently below freezing in my work space), main thought is the oil cooler here.
P.S. Other work includes Dana 60
, ZF5, BHAF, new gears in rear axle, some different interior parts, more gauges, possibly some new body panels (and paint of coarse), probably changing my belt system the serp. setup has been ******* me off for about 6 years now so I'm thinking V (the main reason I don't want the radiator in while I'm working on it), stacks (I've lit 3 fields on fire with my exhaust
), and some other miscellaneous BS.
