1992 has 340,000 and tired. Ran test and all cyclinders were close, first hit was around 175 then up to 300 plus or minus. Engine was run for a while befor removing most of items in way as either engine comes out and slight rebuid or replaced. Of 4 books on ford diesels, one said 440 is good number. I removed injectors and used adapter for test. glowplugs were left in. I can reinstall injectors and use glowplug adapter and try again ,if that gives better reading. What is the best way to do test and what numbers should there be. Engine smoked when started but cleared up, so I though it was vaves or seals and had spare heads rebuilt. I appreciate all answers as this site has a large and smart pool of knowledge.
Thanks
Thanks
