Truck - 1993 F250 Factory Turbo 5 spd 4 WD Ex Cab.
I dropped the tranny because my slave cylinders kept failing. I could not even move the slave cylinder forks with a pry bar. It was tight, like it was hung up. I don't think the clutch is too bad, but since I have torn it down I am replacing it with a single mass set up anyway. The throwout bearing looked ok but, it does not move really that well on the input shaft. I slid the new one on and it just doesn't feel right. Maybe that is my in-experience...
Either way I am looking for guidance and tips, tricks or whatever you feel is necessary. I am hoping that this is upgrade will stop the failing slave cylinders. It cannot figure out what is causing the slaves to fail. I have been through 10 of them, I know they are not that poorly manufactured. I used the ones from O'reillys, maybe that is my problem.
I have found 4 bad glow plugs as well, I am replacing them. The truck has Motorcraft/Beru plugs and that is what I am going back with. I just can't get the back 2 on the passengers side. The only way I see to do that is to remove the turbo, I have no idea how to remove the turbo. Any help on that would be greatly appreciated. I need to check the back 2 glow plugs and replace with new ones.
The old dual mass
The new single mass.
Should I replace my rear main seal? Ford Motorcraft is 73 bux, O'reilly felpro is 24 bux. I have heard plenty of issues regarding non Motorcraft parts. Does this apply to seals and gaskets at well? What do I need to do or get to make the job easier? Tools, tips and or tricks. I have never changed out a rear main on a 7.3 before. Is this something that would be better suited for a qualified professional? Also, should I put Teflon tape on my oil sending unit since I can get to it relatively easily?
What is up with my transfer case? Is there something missing? It seems ok but I would like to know what this is and if I need to fix it while I have it out.
Thanks for everything and all the replies. Sorry the post is so large and long.
John
Either way I am looking for guidance and tips, tricks or whatever you feel is necessary. I am hoping that this is upgrade will stop the failing slave cylinders. It cannot figure out what is causing the slaves to fail. I have been through 10 of them, I know they are not that poorly manufactured. I used the ones from O'reillys, maybe that is my problem. I have found 4 bad glow plugs as well, I am replacing them. The truck has Motorcraft/Beru plugs and that is what I am going back with. I just can't get the back 2 on the passengers side. The only way I see to do that is to remove the turbo, I have no idea how to remove the turbo. Any help on that would be greatly appreciated. I need to check the back 2 glow plugs and replace with new ones.
The old dual mass
John
Anyway they are easy to install with the plate removed and on a bench. You will need to install the new double lip seal deeper in the plate than the now seal is. Test fit the plate and find out this too. Use plenty of brakeclean on the pan gasket corners and then use a good quality rtv. I use permatex copper plus because it has never leaked. Others like other stuff. The seal body to plate require some sealant too. I use permatex avaiation cement for that. Kinda blackish brown stuff in a small container. There is a gasket behind the seal plate but... You really don't need it. RTV works fine there too. Actually ford never used a oil pan gasket but used only rtv so... If it works there it works on the plate... same oil everywhere. The double lip seal will have directions telling you not to remove the wear ring from the seal.... They state it will ruin the seal.... Nope but... Be careful how you install these two parts and all will be fine......
and the happy bar and BFH...happy bar = 5' demolition bar with chisel end...oh ya...baby
