Diesel Max
93 F-250 4X4 - 7.3
I measured the slave today. It moved about 1/2 inch. I assume thats not enough.
No, that is not near enough...... I would tend to believe you have a bad M/C or slave cylinder. If you don't see any external leaks, you may have bad seals in either the master or slave and either one or both may be leaking internally.
