acleary555
Ok heres the long and short- Ive got a 92 f350 and I just replaced the clutch and DMF flywheel with a solid flywheel conversion and clutch kit. All went well with the replacement, Except I let the slave cylinder push rod push all the way out so apparently ive gotten air into my clutch system. I spent four hours trying to bleed it and still have jack for pedal and cant get into reverse so Im SURE there is air in the system. The truck is level, on a lift, and Ive heard of air getting trapped in the master? If anyone knows how I can get it bled please help. Thank you.
