Clearing out some of the hoard
gonecrazyi
florida
Ive decided to get rid of some of the parts Ive been saving for projects. Here's a list containing most of what I have.
-2 gearvendors units
- 1 I know worked when pulled - 850 obo
- the second I have never seen work - 500obo
- Three gearvendors adapters
- 1 1356 tcase adapter with coupler - 300
- 1 th400 2wd adapter with coupler and input shaft - 250
- 1 cummins 727 adapter with coupler and input shaft- 250
Dodge kingpin 60 with 410s, dually outers needs rebuild - 650 obo with matching rear
Dodge dually kindpin 60 dually outers - 150 obo
- 2 2wd cummins 727 transmissons, one is rebuilt with 400 miles on it.
- Several 3.08 geared dodge 8 lug dana axles - 250
Cummins Allison adapter plate and convertor still on engine - 100obo
- Spicer direct drive 5 speed with everything needed to bolt it to a cummins - 650 obo needs shifter tower
- 1 ford dana 61 rear with 3.08s, I need to open the cover to check the gears but they should be the same as a dodge
- t18 ford transmission setup that's bolted to a 6bt, 600 for everything connected to it
- Several cummins engines that are being pieced out if you need anything.
Onto the ford stuff.
- Several Obs fenders, rust free - 100 apiece obo
- Red Obs interior from a single cab, let me know what you need
- 83 ford long bed. No rust or major dents on the sides. Floor is solid other than a bit of rust under the tool box - 150 obo
- Good 83 fenders and core support
- 50 apiece for the fenders
- 150 for the core support
- ATS 093 turbo kit with 3 inch downpipe, complete - 700
- Hypermax turbo from a 5 speed truck - low miles, worked great when pulled to swap the motor to another truck - 650 obo
- 2 sidewinder kits, have enough parts to almost have a complete kit. Just missing the cdr adapter and intake plate - 650 for a 90% kit
- Second kit is mainly exhaust pieces and odds and ends. I can check what all is there if anyone needs anything specific.
- Prelube oil pump system that runs before and after the engine is started and shut off. Has a timer to set length of run time. Allows oil flow for cooling turbo without having to have the engine run. Can easily be adapted to anything, but was bought for a chevy 6.2 and has the oil pan fitting and oil filter fitting - 250 obo
- Complete hydroboost swap - $200 and I can be swapped out for a new unit. I have manual pedal assemblies I just need to find them
- Several 4.10 geared cab n chassis axles. One has 4x4 dually rims - 150 apiece
- 6.9 diesel engine, runs great - 650 obo
- c6 4x4 diesel transmission, shifted fine before pulling - 150 obo
- Lots of tcases - 75 apiece obo
-Mint blue 87-91 interior for a crewcab - Let me know what you need
- 4x4 E4od with new torque convertor - 175 obo
- One good drivers side dually fendor, other side has cracking in bottom corner - 75 obo
- Several tailgates of various conditions, All rust free, some have a few dings or need handles - 50 to 100 apiece
- I have several bins of misc. 6.9 and 7.3 parts, let me know what you need and Ill find it.
- Mint Blue bronco interior with mint eddie bower style bucket seats - 75 a seat
- 2wd diesel zf 5, shifts like new - 650 obo
- Ford dana 60 dually hubs - 200 obo
Tons of other parts I know Im forgetting
I am open to all offers and trades, if you don't see it here just ask as I probably have it.
gonecrazyi
florida
Lol, That doesn't even scratch the surface of all the dodge/cummins stuff I haven't gone through
I need the blue front door panels, are they lariat, if so ill take the rears also. Also kick panels? Any core 7.3 inj pumps?
gonecrazyi
florida
Type4 pm me your email and I will send you pictures. The truck is a lariat. ll have to check if I have any spare pumps.
I'm located in Florida south of Daytona beach
CDX825
filtration nut
Litchfield,Ohio
Would you be willing to ship the 83 core support and fenders?
Good sheet metal is scarce around here!
gonecrazyi
florida
I've got a few motors I'm about to tear apart. Have to get my bobcat going first to get it out of the truck.
I think I have a few coolers left I'll check.
As for the core support and fenders. My cousin may be coming down in a few months but I can check on shipping
Goose_ss4
ca
tell me more about that Spicer five speed, could it bolt to an idi?
jayro88
Auburn IN
Are the Gear Vendor units P or J units and do they come with all the electronics needed for installation?
tke395
