clear tube pre-IP
anson
SO, as a means to spot bubbles in the system since I'm installing a looped return..
I've read that you can use one of those small clear inline filters but the ones I saw at the store looked awful small and all I need is clear tubing of some kind, but what kind?
thanks!
gamudslinger88
I was wondering about this also. After a trans rebuild/swap I am planning on fixing everything for bio-go-juice and was curious about compatable clear fuel lines. I am having problems with air getting in somewhere, I replaced the return caps and o rings but about 2 or 3 caps still are wet. I recon I messed up the orings when installing them.:puke: Ohh well I have a pack of 50 viton orings just waiting install. Im not going to install all 50 of coarse, thats just how they camecookoo
You can use clear vinyl tubing. It won't last forever, but for troubleshooting it works fine.
MIDNIGHT RIDER
TEK SUPPLY, a green-house supply company, has solvent-proof clear flexible hose that will work for fuel.
This stuff has nylon cords in it's construction and is plenty stout.
http://www.TekSupply.com
http://www.teksupply.com/farm/suppl...ccessories-ts1_bulk_hose;pgwf1050_wf1060.html
As for the clear in-line fuel-filters, I have one ahead of my piston-lift-pump, to catch trash before the pump-screen catches it; they work fine for that purpose and are much easier to replace on the roadside than accessing the screen.
