OkieGringo said:
Yeah, what Okie said. I got the Boss from Summit. Not complicated... a feller could build one himself if he had the time and inclination.
I'll snap some photos in awhile... camera battery's tango uniform. Installation isn't final yet.
For the ignition hot relay which handles the ignition hot circuits, the CirKit Boss uses a clip on an ignition-only fuse under the dash panel. I was trying to get away from that kind of stuff, but not bad just to have one such clip.
I haven't converted my gauge lighting yet, and haven't hooked up the CB. One issue is that the best mounting place for the kit is on the fender behind the passenger's side battery. This makes for LONG cable runs if you route cables through the driver's side firewall above the brake pedal/clutch pedal as I do. Long cable runs aren't good.
I'll have to see how the CB handles this (it has a 10 gauge power cable). The accessory cabling with the CirKit Boss is 18 gauge, so that plus a long cable run to the CB might be a little draining, so I haven't "finalized" the kit's location yet as you'll see in the photos.
Photos will be up in a couple hours.
Mike
