Okay, Got everything back together and did the timing. Would really like to upload pictures, but after do browse and select picture, website does not give me option to load. they are .jpg images and should work. So will have to explain with words until can figure out pictures. Done so far.
1. Took IP and drive gear completely off.
2. Install new Delphi injectors.
3. Installed drive gear, double and triple checked two "Y" aligned.
4. Installed everything else.
5. IP factory timing mark and gear housing timing mark aligned exactly as they had before.
6. Started and warmed up engine. Stopped engine.
7. Hooked up MacTools ET18DPM Pulse Inducer to #1 cylinder fuel line. 1st cylinder on passenger side, nearest radiator.
8. Hooked up new Innova 3568 to battery and ET18DPM.
9. Started engine, used turnbuckle to set RPM to 1400.
10. Turned on timing light, adjusted 3568 negative till damper mark aligned to "0" timing mark.
11. Timing, according to 3568, is 43 degrees BTDC.
Know readers 1st reaction is that IP drive gear must be off a tooth or two. Or maybe wrong Cylinder fuel line.
No, am 100% sure IP gear and Cam gear are aligned correctly. And this is why really want to add pictures.
Made two tools for aligning gears.
1. A probe like a dentist tool, with tiny pointed 90 degree end.
With Damper at "0" DTC. used tool to feel location of "Y" groove on cam gear. Then marked groove with paint. Mark "Y" tooth on IP gear. Lowered gears into place.
2. With gears in place, made another tool. Start with thin, flexible metal yard stick. On one end pressed thin layer of plumbers putty. Thin enough that yard stick with putty clears the 1/8 gap between front housing plate and gears. Pressed putty onto gears and removed. Very clear impression of gears and "Y" marks and gears. Removed gear, intentionally off-set gears by one tooth in both directions and made putty imprints to see what bad alignment looked like. Then did correct alignment and putty imprints twice.
With this method, had direct visual verification that "Y" marks were aligned correctly.
The factory IP timing mark is about 3/16th below the factory timing mark on gear housing.
If I understand correctly...Rotating IP upwards, or towards passenger side, also towards factory gear housing timing mark, will advance timing. Because this gap is around three dime thicknesses, maybe getting the two factory timing marks close to aligned will get my timing close to 10 BTC.
Will do that after taking a break. Tried it and pump refuses to move. Going to have to start loosing up fuel lines until can get pump to turn.
Later
