Get the Banks CDR relocator that will give you a hose nipple on your pump bolt cover at the front of your engine and bolt a new CDR to the 088 air filter housing, then take a piece of heavy wire and bend it to make the trip between the fittings ( hint, get a few old coat hangers and bend them up a few different routes ) then take these wires to your friendly neighborhood parts store and spend an afterrnoon digging through pre bent heater hoses till you find one or two that will match the fittings and bends , or go to a hose shop and get a chunk of breather hose straight and wriggle it in and hope it doesnt kink, you can get curved corner supports to prevent kinking on 90 deg corners that are made from plastic and metal that snap over the hose
