jimraelee
Well my new truck has a flaw... bad defrost. After inspecting the ac system, I found it was a bit low on freon... no big deal... dumped in 2 lbs of freon and pres is still on the low side, the high pres side ( should be 2.5 times ambient) is only pumping 50-75psi.. Sounds like the pump is trashed. Looking at new pump, dryer and orphas tube. What are my alternatives for Freon... R12 was on its way out when I was in the bizz.(some 10yr ago) and R134a is the new cool refrigerant. Is there a compatible gas to use in a R12 system??? I don't really want to change out all the rubber lines and swap over totally.
thx
thx
