Camper relay ign feed.
typ4
Newberg,OR
On the 91 does anyone know if the ign. wire in the 4 pin connector for trailer wiring is relay controlled, It was switched and now its hot all the time. :mad: Just wondered if anyone has seen or dealt with this. thanks in advance. :hail
Or a wire diagram pic would be cool. ;Sweet
russ
krawlr
Yup, that's me
Cincinnati, OH
The white/red tracer should only be hot with the relay on. The relay should only come on when the marker lights are on.
Can we attach pics in PM's?
Exekiel69
Post it for every one please. :angel:
typ4
Newberg,OR
I should have been more clear , it is the bat. charging solenoid that I need to power. I dont have the factory trailer tow package but the connector it plugs into is on the fenderwell, 1 bat feed thru a fuse link, one switched ign and 2 pass thru to a connector under the dash. The ign one doesnt turn off and on anymore ,just hot all the time
krawlr
Yup, that's me
Cincinnati, OH
I don't see anything like that in the diagrams but I'll keep digging.
Exekiel69, it's from my a l l d a t a account, I don't want to get in trouble with them. If you guys need info from there I'll post text but pics need to be sent in a non public kind of way. ;Really
typ4
Newberg,OR
thanks krawler, We are heading out the door so I will use any info you find and post the fix asap. The wire did turn off and on before, unless the ign sw is bad but then I would figure other things would be on. I will be into it deep soon the turn sig switch just gave up both detents, I love column work, tilt and cruise.
thanks again
krawlr
Yup, that's me
Cincinnati, OH
Man I just don't see what you're talking about. I guess this a dealer installed system that just doesn't make it into the book. I've found quite a few holes in the info on this truck, they've never let me down on the 'yota or the Marquis.
typ4
Newberg,OR
I will do some digging an post what I find out. thanks for looking
russ
