Dexron is the GM equivalent to Fords type F. Type F doesn't have the additives like Mercon. So type F will make the shifts a little more firm.
I am going to have to disagree on that one, or it just may be a wording error. Dexron has always been different than type F in all the literature and car manuals I have used.
Since the new oils are called "Dexron/Mercon" I am assuming that Dexron and Mercon are the same fluid, while type F still stands by itself as a different oil. Then you have the Chrysler ATF4 which is another different oil.
I don't know exactly what is different about each of the 3 types of oils I listed above, it may be weight, it probably is some additives, but whatever it is they are different families of oils for different applications.
Most all the all Fords did use type F from the 70's down, and probably the older c6's did use type F. The newer ones do call for Dexron/Mercon, but I don't know if there is a difference in the later trannies.
